The title isn't being inflammatory, the life-span that I'm getting from Fleetgard filters in the '95's stock air box is pitiful. Filter minder is typically 1/2 down by the first oil change, and that's with little in the way of dirt roads involved. As the truck is 4wd and we typically use that at least once on each trip (& trips are all that the truck is used for) it means that I'm getting maybe 5k miles from an air filter - max. I don't need more power. I don't need more airflow. I need a filter that lasts a reasonable time period and 5k seems remarkably short. From my readings the solution isn't a "BHAF", nor do I want the noise that comes with one of those.
Truck came to us with a K&N in it. Based on my previous poor experiences with those replacing it was my first "mod" to the truck, prior to even reading anything about not using one on these engines. Speaking of, the truck is nearly stock. Trans had some work done and it has a 4" exhaust w/ 60" truck muffler and a TST 250HP fuel cam. That's it. All filters used are Fleetgard.
What am I doing wrong?
Suggestions?
EDIT: I note that Wix lists two filters for this truck, one is 2.25" thick and the other is 2.75" thick, but neither of the Fleetguard filters that cross from those Wix numbers are more than 2.25" thick. As I use Wix on everything else I am tempted to try the thicker filter.
Suggestions?
