KevinPhillips,
Yes the AFE Pro Guard 7 flows the air but stops the dirt, check this out, it applies to any 4 layer gauze filter etc:
SPICER Posted: 16 July 2004 at 3:47pm | IP Logged | Report Post
Diesel Addict
Group: Diesel Addict
Posts: 302 The following is the complete test results. In order of rank from BEST performance to WORST in the categories of FILTERING EFFICIENCY, FLOW RESTRICTION, DIRT HOLDING CAPACITY and TOTAL DIRT PASSING THE FILTER DURING TEST.
SPICER wrote:
In the order of filtering efficiency the results are:
FILTER % Efficiency
AC Delco OE 99. 93%
Baldwin 99. 72%
No name filter (made for gas engine, 1/3 less pleats) 99. 32%
AFE ProGuard 7 (73-10062), panel filter 99. 23%
WIX/Napa 99. 03%
Purolator 98. 73%
Amsoil, new style 98. 63%
UNI 97. 93%
K&N 96. 80%
Additionally, these 2 were tested using FINE test dust. The K&N was cleaned and retested, the AFE was the conical version:
K&N 89. 85%
AFE Conical 92. 33%
FLOW RESTRICTION FROM BEST TO WORST:
FILTER RESTRICTION in Inches H2O
K&N 4. 54
Mystery bargain filter 4. 78
AFE Pro Guard 7 Panel 4. 99
Purolator 5. 05
WIX/Napa 5. 06
UNI 5. 40
Baldwin 5. 71
Amsoil 5. 88
AC Delco 6. 23
TOTAL DIRT PASSING THE FILTER DURING THE TEST. This is how much dirt your engine will take in if you use the filter for the duration that would cause the filter to become "dirty" enough to need replacement or cleaning. The "Dirt Passing The Filter" is the dirt collected by the "Post Filter" during the test.
FILTER DIRT IN GRAMS PASSED
AC Delco 0. 4 g
Baldwin 1. 1g
AFE Pro Guard 7 1. 8g
Mystery Bargain 2. 4g
Amsoil 2. 7g
WIX/Napa 4. 4g
Purolator 5. 0g
K&N 6. 0g
UNI 7. 9g
Note: The Purolator was reported to have a seal malfunction during the test and passed more dirt than it would have with a good seal.
Interesting. SPICER
As you can see the PG7 did very well, call us if you have any questions or need a system.
Mark @ DPPI
