Air Flow from Climate Control System
The Cat
06 dodge frame
I have a 2004 Quad Cab. I have no fresh air flowing from the climate control system.
The way I understand how the climate control system works, is that the selector in any other position than re circirculate will allow fresh to come into the selected vents (ie defrost, down at your feet or from the dash vents.
I am getting no fresh air at all. Dodge service manager is not sure if I should be getting fresh air. But the way I read the owners manual and from other friends that owns 2005 trucks, I should be getting fresh air.
Any advice or suggestions?
Thanks
-- email address removed --
There's probably a broken door or door-actuator somewhere behind the dash. How are you so certain you're not getting fresh air? I mean, how do you know the system is stuck in "recirculate"?
Ryan
