Engine/Transmission (1994 - 1998) air flow?
2nd Gen Non-Engine/Transmission 97 wheel bearing question
2nd Gen Non-Engine/Transmission Who makes the best exhaust brake?
how much air does a BHAF flow compared to the AFE PG7 stage one. i recently installed this turbo and injectors and my towing temps are higher than i think they should be. i have to down shift to 4th if im on any hill for longer than 30 seconds or i will be around 1200*. this is towing less than 4k in a 6x12 cargo trailer @ 60-65mph. 3. 55's w/315's
My BHAF (Part # AH19037, from TST), When put on a flow bench on the highest range, flowed enough air that we could NOT adjust it down to the normal readings. That means it flows in the 800-1000 cfm range.
maybe i have too much fuel for this turbo then. i thought the egt relief would be better than that. im gonna try a friends afe tomarrow and see what happens.
Has anyone tried adapting a one of the Ford Severe Duty AIS units on our trucks? I don't remember all the specs on it, but it's supposed to be a very good filter (Donaldson) - good flow and filtration #s.
-john
