i started my truck the other day and the voltage meter would go back and forth real fast not like the usual deep cycling the lights were actually blinking and the door buzzer was breaking up i checked all the connections at the air heater and relays i noticed one of the 4 wires on the relays was loose i pulled it off the post looks like it has ben burnt or corroded its hard to tell i cleaned it up the best i could and re attached it it did not clip on real good but it seemed to clear up the problem there is a nut at the bottom of the post i was wondering if you could change the post by itself or you had to change the entire relay as one unit thanks for any help
