OK, here's the 1st half. The whole thing was almost 7,000 characters too long for one reply. I've saved the other half and ill post it to a second reply in a few minutes.
My twin-trumpet Grover model 1167 unit is installed in my '81 Chev 1-ton crewcab DRW 4X2 GAS truck. Just bought an '03 Dodge HO 3500 QC LWB SRW 4X2 48RE 3. 73; going to sell the Chev. The mechanics of my installation will translate OK over to the Dodge, but the locations of the items won't.
I installed the entire thing under the hood, and managed to finesse the twin trumpets through an opening in the front of the truck so they are right behind the grill on the left side. Since other drivers' "blind spot" is in their own right rear quarter of their own vehicle, I wanted the trumpets on the left side of my vehicle.
If you mount the trumpets in any location where they are in the path of flying debris, such as insects, pebbles, gravel, etc. , then you need to put screens over the trumpet bells. Since mine are behind the grill, I used fiberglass window screen, and held it in place with a cable tie around the body of each trumpet just behind the bell. If you are going to mount your trumpets underneath, along the frame or something similar, I'd put the window screen on first, then light-weight metal screening, such as 1/8" hardware cloth, over the window screen, to keep out the pebbles and gravel.
I mounted the 1167 pump unit under the hood, in an accessible location on top of the left fender well. The unit pulls a lot of current when it's pumping, so I installed a fuse block and wired it directly to the battery through the fuse block.
Because it pulls a lot of current, and for a number of other reasons (more below) I wanted to be able to turn the pump circuit off, so that it wouldn't come on when the truck was parked. I used a marine type solenoid (NOT grounded through the solenoid body). The marine type is easy to identify: the automobile type has three terminals -- two for the heavy power circuit and only one for the switch that turns it on and off. The marine type has four terminals -- two for the heavy power circuit and two for the switch. You don't want this solenoid grounded to the negative side of your electrical system. With the marine type I was able to bolt it directly to the top if the front left wheel well.
I wired the pump to the battery through the solenoid (and the fuse block). Then I installed an "on-off" switch at the bottom of the dash inside the cab, so I could turn the solenoid on and off.
When "off," the solenoid does not operate and the pump/compressor is not energized even when the pressure in the tank falls below the level at which the pressure activated switch on the Grover pump switches to "on. "
I did this primarily for three reasons: With a full tank of air (105 PSI and in my case, a freon a/c service tank, the sort of semi-flat "pancake" or "donut" type) it wasn't necessary for the air compressor to come on every time the pressure dropped to 90 lbs; when I took the truck for service I could vent the tank and turn the pump "off," so that service personnel would not accidentally inundate their fellow workers with an unexpected air horn blast; and most importantly, the plastic air lines and their associated brass compression fittings leak air if the nighttime temperature drops below about 60 degrees. Every morning I'd have to put up the tank from scratch. Also, if I didn't have the shut-off switch, the air-pressure switch on the Grover compressor would keep cycling the compressor: Nighttime temperature would fall, air lines would leak, compressor would come on and fill tank, then shut off; lines would leak, pressure would fall, air compressor would come on, etc. , etc. -- and in the morning (or a few days later if the truck was parked for a little while) the battery (ies) would be dead. Since most on-off switches would not handle the compressor main power circuit passing through them, the solenoid was a necessity.
In my experience the Grover model 1167 compressor unit has been a maintenance hog. The compressor crankcase is fastened to the 12-volt electrical motor with only TWO machine screws. The aluminum crankcase unit is filled with 40 wt oil, and seals to the body of the motor with a gasket. TWO machine screws simply don't keep it tight, and it leaks oil. It needs four at a minimum, and preferably six. When I was at the Grover factory about 18 months ago to pick up some parts (more below) I met with one of their lead technicians/designers. He said they had "plans" to increase the screws to four, but I'll be it hasn't happened yet.
Somewhere, somplace I learned that most of the big-rig owners seal the aluminum crankcase to the electrical motor body with epoxy, and put loc-tite on the threads of the two machine screws. I did it as follows: First I tried clear silicone sealer, which did not turn out to be satisfactory. Then, I bought some heavy paper gasket material and made my own heavy-duty "crankcase-to-motor" gasket. I got everything clean and tidy, then coated all mating surfaces with a light coat of oil, including the gasket. I applied epoxy to both the crankcase mounting surfaces and the motor surfaces, with the heavy paper gasket in-between. I also stuffed the air-vent in the crankcase rim with a small wad of paper-towel material, so the epoxy would not block the vent -- the "splash" lubricating system generates enough pressure that it will rupture the seal if you block up the air vent. I then screwed it down with the two mounting screws. Once the epoxy set, I removed the screws, put loc-tite on them, and reinstalled. I know it works because I had to take it apart again a few days later, (more below) and was able to get the crankcase off fairly easily, and peel the epoxy off of the mating surfaces, then start over.
If you get a Grover 1167 model, once you mount the compressor unit the oil fill hole may not be accessible. For a couple of years I used to fill it with a railroad style oil can that had a thumb pump and a long flexible fill tube. Then I finally installed a brass 1/8-inch "street L" fitting -- female on one end, male on the other, bends 90 degrees -- into the threaded oil fill hold, and oriented the "street L" female opening so that any oil can would work -- and the Grover threaded oil fill plug screws into the open end of the "street L". You can't install anything longer or larger than a small 1/8-inch "street L", or even add a four inch piece of 1/8' brass pipe to it to make the resevoir easier to fill, for two reasons:
40 wt oil will not flow down that narrow hole with any thing other than glacial speed, and if you put anything longer than the street-L on it the vibration will eventually crack the aluminum crankcase.
I've had to replace the compressor piston connecting rod and "crankshaft" roller bearing assemply twice. Once because I broke it myself after reassembling the unit, and a second time because the replacement rod failed.
When you reassemble the crankcase onto the motor body, you have to make sure the eccentric drive pin on the end of the motor armature (drive shaft or "crankshaft") fits neatly into the hole and bearing on the bottom of the connecting rod. If not, not only will the compressor not work, the rotating eccentric pin will break the connecting rod, which is what happened to me. The only way to do this and be sure you've done it correctly is by using a small flashlight to look through the oil fill hole. You can JUST BARELY see the eccentric drive pin mating correctly with the connecting rod bearing.
When I ordered my replacement parts Grover sent me an aluminum connecting rod, rather than a steel one as came with the original unit. After a few months the constant vibration deformed the socket at the bottom of the aluminum connecting rod so that it would no longer hold the roller bearing securely. Of course, I didn't figure this out until I'd reassembled the unit another time (with epoxy) and had to take it apart again a few days later.
When I called Grover in east Los Angeles to order another connecting rod, and to make sure I could get a STEEL one, I learned they had instituted a $25. 00 "small order" surcharge. My order was about $28. 00, PLUS the $25. 00 surcharge! So I decided to drive to east LA -- about 50 miles -- and pick up the parts myself; that was when I was able to speak with the technician/designer. Once there, I learned that Grover had started the surcharge in order to keep their dealers and suppliers from ordering less than $200. 00 of parts and supplies at one time. I pointed out to them that this made NO SENSE for people like me, and that if I hadn't been able to drive economically to east LA, the cost for my repair kit would have DOUBLED; that in my opinion, it made much MORE sense to have this "small order surcharge" only for customers using a resale sales-tax ID number -- their dealers and suppliers -- and to continue to allow their individual consumer clients who bought the product to use in their own vehicles -- like me -- to buy repair kits over the phone with a credit card # and NO surcharge. Well, they looked at me like I was speaking Urdu. In fact, the actual reply was: "Sorry, that's our policy for everyone. "
ADVICE: If you aren't close enough to the Grover factory to go there in person, when you order the original unit, order a repair kit at the same time. If you already have an 1167 or other Grover unit, order a repair kit NOW from your local dealer or supplier, and when that business has orders exceeding $200. 00, you can get your repair kit without the surcharge.
