The Scotty has the option of drilling a large hole into the firewall so fresh outside air is forced in though the same area where the cab vent draws it's air, though the grill work between your hood and windshield. I didn't use a Scotty, only the factory airbox, just copied the Scotty's idea on where to draw the air. All I did was hole saw a hole on the dirty air side of the factory airbox and another in the firewall then connect them together with a large hose. It doesn't need to be a tight fit just as the stock snorkel to wheelwell is a loose fit. It's the same idea as the stock system of sucking air from the wheelwell, just a different location and larger hole. I left the stock snorkel and wheelwell intake intact, air is now drawn though two outside fresh air sources into the stock box. The result was very positive in lowering egts.
