air lift overloads
Late model trailer plug diag.
Getting ready for Prodigy hook up?
I am considering getting the "air lift" air bag overload kit. wich in cab air preasure controler should a guy get, the single or dual? Does anyone with a dual controler use it to level the truck side to side? thanks E. T.
air bag
I installed Air lift air bags on my 1995 2500 CTD when it was new. It has carried a Alpinlite 9. 5 truck camper and pulled a 8000# cargo trailer for about 120,000 miles. I used the individual air switches to level the camper at campgrounds and it worked very well. I also used them to level the truck in strong crosswinds. I never had a bag failure,pump failure or even a broken air line.
The only thing I had to learn is not to over level the truck under load. VERY GOOD PURCHASE!!
I put them on my truck with single switch for control. Figure with a 5th wheel, side to side isn't very important. You always will want equal pressure on both sides.
Helwigs and Airlifts are good
I have Helwigs on my wife's '96 and have Airlifts on the my 2000. I recommend dual fill. You can equalize them, but you won't have air shift from one side to the other in a turn (promotes sway). The dual fill restrict sway.
Wiredawg
