The great air line debate... ... ... sounds good
First, I have NEVER seen a PVC pipe explode when used as a raceway for compressed air. It has a burst rating of 450 psi, which is 2-3 times the average shop pressure.
I have piped several shops for air, and as it just so happens I am about to do another one. I did two with Galvanized Rigid 1" pipe. It works great, looks real fancy if done right and is a one time job. I plumbed all runs in 1" and then reduced to 1/2" where ever there was an connection fitting or a gauge. The down side is of-coarse the cost and extra time required to do the work. 1" rigid is about 15-20 bucks a 10' length, and the fittings required for all the bends, reductions and fastening add up very fast. A simple shop set-up would run somewhere between $3000 to 5000. Larger or more elaborate systems will of coarse add to the bill.
Copper is an alternative, but I have never used it. it's burst strength is not that high and again it is very expensive for what you get. 1" copper is almost as expensive as rigid, but the application goes much faster with copper. Just cut and solder it in, much faster then threading pipe. I do not see any reason that one could not use copper.
PVC. My favorite It is the most cost affective and the quickest to install. PVC looks nice and does not leak it installed correctly. The biggest problems are when you transition from slip joints to threaded joints. The threaded joints require alto of attention to insure they remain leak-free. It's just a case of plastic threads and tapered joints. I use Teflon tape and pipe joint compound on all threaded joints, and use it heavily. I just last winter did our new house and garage with PVC, and with-in the next couple of days will begin piping our new shop for electric, air and water. I will use PVC for all the air lines, copper for the water and EMT conduit for the electric, can't wait.
PVC isn't cheap, but it is about 1/3 the cost of copper and 1/6 the cost of rigid threaded pipe. You do not need any special tools for it's installation and it is basically immune from most household and light garage chemicals. It will not rust (inside mainly) like the rigid pipe will, and it is not conductive like both the copper and rigid pipes are.
We run 2-stage air compressors, with 5 HP motors and 80 gal tanks. I would not run the main lines in anything smaller then 1", and only reduce down as close to the connection as possible. Good luck with your dads shop and enjoy the time together while you still can.
