The question was asked in another thread, "Where have you guys been mounting your tanks and horns?" I did these last week, and thought I'd share.
The Kilby 2. 5 gal air tank is mounted by clamping to the passenger-side frame rail, between the frame and rocker panel. I used two 10" 'L' brackets (one cut off to keep from hitting the rocker panel) at each end of the tank to clamp it to the frame rail.
View from front:
View from rear:
The Train horn is overkill ("too much is just right"), but I couldn't find anyplace it would really fit. The closest is under the bed, above the driveshaft, facing aft. The bells may be subject to getting smacked by the diff on full suspension compression, but it's hard to tell.
View from front:
View from below:
View from front:
View from rear:
View from front:
View from below:
