Airdog Fuel system not making the HP version anymore?
So, howzabout a Holley?
Isspro gauges with cubby hole mount
The website is down and I dont have the number. I have looked on a few other sites and they only list one model. To my knoweledge they were making a HP version. I had to back out on ordering this pump sometime back and have been watching the progress of both pumps. The F. A. S. S. may have the edge if Airdog doesnt have the HP version.
The difference between the 95GPH and 150GPH is how the stators are machined from what i'm told. Any opinions on whether this will cut down pump life? Both versions have the same pump, so either rpm is increased or the stator machining puts more stress on the pump to increase to that many GPH. Ofcourse it may not be enough to make much difference. Any thoughts?
PS I was also told the 150GPM is noticeably louder which I would think would come from more RPM. How noticeable is the noise? (like it will matter much against the cummins :-laf )
I ordered my airdog about a month ago and also noticed no HP version. Figured any would be better than factory setup.
It is a little louder than factory lift pump. Install went perfect besides removing hose from stock pickup tube. Fuel pressure hasn't dropped below 16psi on digital gauge.
I got the HP version last Aug. The only time I hear it is when I first hit the key. I don't think my 5" straight pipe is quiet enough to hear it run after the Cummins fires up though.
Al
