Stock lift pump died, so I replaced it with the airtex unit that mounts in the same location. It was OK, not perfect though as I could pull it down below 10 psi pretty easily.
Then it got worse - it would sometimes drop to 0 for a second all by itself, and I could easily pull it down to 0 when accelerating. I figured maybe I got a dud pump and replaced it with another.
A little better, but it just put me back where I was before: a brief shot to 20 psi before I fire the engine up, then idles at 16. Pretty easy to drop it below 10 psi, and if I really get on it, it will drop just below 5.
Time for the tank to come out - I found the 'screen' at the bottom of the tank module had some tears in it and was coming apart. I removed it, and got a fleetguard in-line strainer. Put the tank back on the truck - same results. I did some reading and discovered there's another screen buried within the module inside the cylindrical thing. Tank came out again to check it. That screen was clean. I'm very good at dropping fuel tanks now.
There are no leaks in the tank module or lines, and no restrictions that I can find, I inspected the entire fuel line. I put clear hose on to check for air, no bubbles present.
I have a new fuel filter, and I have also verified that I get a full 12 volts to the pump while the engine is running. I also put a second gauge on to the inlet side of the fuel filter, and it shows the same results, so I know there's no restrictions in the fuel filter assembly.
I'm out of ideas. I'd expect to pull the fuel pressure down that low if I had some serious mods, but I don't have anything fuel-related in the way of mods on this truck.
