Aisen fluid change
2017 3500 6.7TD thermostat replacement
CROW
Still haven't gotten around to completing this task and have everything needed. 7.2 quarts seems to be the correct number for a 30K drain without dropping the pan. Understand you need to check at the correct temp.
Are you draining with the fluid hot, cold or somewhere in between?
Thanks
Drain it at operating temperature. As a rule....you’ll yield little additional fluid after about :30 or so of draining, based on my experiences.
