DonRam240
See the archived 4th Gen forum thread "Aisin "limp home" symptom under load in hot weather" for reference. Again had similar EVIC messages towing/hauling camper in hot summer weather, like "4WD system unavailable". Do not remember having it stick in the 4th gear only limp home mode this year, although I'm not sure I waited before stopping and shutting down/restarting engine to correct it, so I could have missed that symptom this year. Just had dealer service done and they found code P0970 "stored". It had been cleared after the warranty repair on the transmission the previous year, so if I'm correct the stored code must have been recorded after the repair, presumably this past summer? That is the same code that was the pertinent one leading to the repair.
I asked them to check the wiring connector behind the wheel well liner, driver side front, that TransEngineer has said causes issues in some trucks with Aisin trans. They found no problem, mechanic saying, "do not see any issues at this time, pulled on wires, all solid at this time". I don't know if that reflects the level of inspection needed to find what we were looking for, didn't say he disconnected and checked for pushed-back pins/sockets, etc. I'm asking the service writer to ask the mechanic, will add more here if new information on the connector.
The Aisin's valve body was replaced, so barring a defective/failed replacement, it looks like there is another gremlin involved. Mech's advice was to pursue the new code if it is set again later. I think my basic generic code reader catches that code, so will scan SOON after any recurrence of the symptoms.
