Wiredawg,
Aisin website info is not real generous. I have looked at various links several times and never found anything specific.
It may be a safe bet that the Cummins used in our C&Cs is detuned for the Aisin factory specified limits . . . ie 305hp and 610tq.
It could be that the engine is derated since it has the potential to be used in a high horsepower PTO operation such as running hydraulic or water pumps. In high horsepower PTO applications, engine heat rejection is a big problem since the truck isn't moving.
Bill
I found some info on the web. See the link:
http://www.atra.com/AM/Template.cfm?Section=Home&CONTENTID=1694&TEMPLATE=/CM/ContentDisplay.cfm
I tried to attach the pdf but its too large. It says that the maximum torque for the AS68RC (also known as A456) is 730 ft-lbs. It also says the max torque for the Cummins 6. 7L is 565 ft-lbs which doesn't match any specs that I've seen before so take it as is.
