Aisin trans service tips
2013 DRW Manual, a couple issues.
Fuel Filter Service Life
Well it was time for a trans service with filter on my Ram 6.7 Aisin trans. As people before me know the back 4 bolts are a pain in the ass because of a crossmember. A trick I learned was using a short swivel socket, specifically this one. Amazon product ASIN B07R7JKG74
I also used what’s known as a wobble extension, but probably not needed. The outer 2 bolts I was able to remove with the above socket. The middle two had to be loosened and then using a 1/2” OD 3/8” ID vinyl tubing to extract the bolt. It was a trick that I saw on YouTube.
Ground down in diameter and length 6 point 10mm socket with 1/4” wobble end extension works great for me. Spray glue the gasket to the pan makes easy assembly.
