I am the 2nd owner of a 98 12valve 5spd 4x4 2500 LB and it appears to have a factory alarm system as the key fob looks factory ie Chrysler logo. The problem is if I do not pull the fuse on the horn it just goes bonkers more often than not I have it going off.
I badly want to chuck this piece of crap,and tried by bypassing what appeared to be the brain by disconnecting it and hotwiring the starter. The result it would only start if the door was opened. A Dodge dealer said look for the hood switch and disable that,but none was found.
I might add all fuses and relays are aok. I so want to sling this alarm system over the hill,if you can call it that!! Please advise???
Liberty Warrior
Liberty Warrior
