2nd Gen Non-Engine/Transmission Algae/Fungi Contamination in Fuel Tank
2nd Gen Non-Engine/Transmission need apps
Greetings! I thought that I would share a discovery that I made when I installed a Vulcan Draw Straw in my truck’s fuel tank last weekend. It was quite a surprise to me. I realize now why my truck is on its’ 5th LP. When I pulled the fuel tank module, the bottom screen was 75% covered with black and tan colored algae/fungi. The stuff was even on part of the top screen. When I cleaned out the fuel tank, I found numerous little blobs of the tan stuff. Other than that, the tank was spotless. As far as cleaning goes, all I did was wipe out the tank with lint free cloths as best I could. I had already drained virtually all of the fuel.
After I got everything back together, I decided to do some research on “diesel biocides”. I looked at three products: Racor Diesel Biocide; Power Services Biokleen Diesel Fuel Biocide and FPPFs’ Killem. I chose the Racor product based on its’ product description, price and the fact that it could be had in a 16 oz. container (treats 1,280 gals. ). After I received it, I put 1 oz. in a full tank of fuel. The literature called for a “shock” treatment of 1 oz. for 40 gals. of fuel and . 5 oz. for maintenance. I plan to put the biocide in one more tank of fuel after this application – just to be safe. After this is over, then I will put it in once a year.
The sad part about this is that I’ve known about using a biocide since I bought my truck in March 2002. I had read about this maintenance tip on several of the Dodge diesel websites; unfortunately I didn’t pay any attention to it. I changed the fuel filter on my truck once a year or 10k miles and never saw any evidence of algae/fungi contamination. In retrospect, I believe that my truck’s problem started with the fact that it sat on the dealers’ lot for 5 months before I bought it. Obviously the fuel tank had little fuel in it during that time. It probably had plenty of moisture in it though – great opportunity for the algae/fungi to get started.
Bio-cide is always a part of my trucks maintenance. I had an old bread truck that had it once. I couldn't even blow air thru the lines either way. After I raised the pressure to 80 it finally blew thru it. I dosed it strong, ran it for a day then did it again with a gallon of gas to a full tank.
I got it.
Do you think it is something about the fuel you buy, the Texas climate or some other variable that caused this. Also, how did your fuel filter look while all this was going on?
I'm just wondering if I should start doing a biocide treatment periodically.
I live in north central Texas where the climate is generally hot and humid. The winter season does not get that cold. I have owned the truck since new and I have always bought my fuel at a Valero/Diamond Shamrock station. Usually I buy from the same two stations. I believe that Valero/Diamond Shamrock has a refinery on the Texas gulf coast. As I stated in my initial post, I change the fuel filters at 12 months or 10k miles. I have never noticed algae/fungi in the fuel filter cannister or on the fuel filter itself. The WIF sensor has never activated to my knowledge. From now on, at least once a year, I will put some biocide in the tank.
Algae grows much faster in a hot and humid climate. It really doesn't hurt to put biocide in your tank once or twice a year even if you don't think that you have a problem. The biggest things that you can do are to make sure that you buy from a place that sells a lot of fuel and to keep your tank full with biocide in it if you are going to park your truck for a while.
For the price I guess it's cheap insurance... moss and algae grow on everything else in SW Washington...
I dont buy anything from Valero aka Citgo as all the stations are owned by dictator Hugo Chavez. My 2 cents
I have used Racor Bibore since my truck was new. Still on original injection pump and changed out my lift pump at 50k when pressure was down to 8 psi WOT. I also use Almalgamated in every tank of fuel. But now it appears that my fuel gauge float has gone bad. I am out of fuel when my fuel gauge registers just below 1/2 tank. I am now wondering if the biobore that I use once per year attached the fuel sensor float? I wonder what material the float is made out of? I will be dropping the tank this winter and take a peak at what I see inside. Large swings in ambient air temperature also has a major impact on algae formation due to condensation in the tank.
Valero-Chavez?
Educate me Moe, from what I can see Valero is corporately owned and most if not all of it's oil and refinerys are U. S. and Canadian. Sorry for the hi-jack.
