2nd Gen Non-Engine/Transmission Alignment and Cab-Chassis Caster Correlation Value
2nd Gen Non-Engine/Transmission Bulb numbers
If there are any alignment guys or knowedge regarding the Cab-Chassis Caster Correlation Value, I could use it. Its in the service and I would like to find out what it applies to? I'm thinking it might apply to my truck. I have a 99 4x4 with leveling kit. So essentially I raised both the rear and front end to be level. This changes frame angle, thus changing caster. So I think I can use the Cab-Chassis Correlation value to determine the right caster range. Is this correct?
Thanks
dish
