That depends on your lower king pins, I have seen some trucks with a special lower king pin that allows you adjust the camber as well, If you have these king pins it will look like two large nuts one on top the other in the center of the king pin plate.
On a Dodge? Never seen those before!
MM
Correct as for most non special edition RWherley trucks.(Poke poke :-laf)
That's funny coming from the guy building a dually limo in his shop
I don't know if they where factory and I have only seen one truck with them but you can the kit to put them in from Moog but they aren't cheap and in most cases I think not needed
Its true I already have a different transmission laying on the shop floor, but you know how it is the more custom stuff you do the cooler it becomes.
