Alignment specs with KORE Chase System
Painting Driveshafts
I know I've seen something on here regarding alignments... ... ... ... ... ... maybe it's just Friday night Oo. ????
The KORE system is designed to use the stock specs, however, you will find at TDR that some folk recommend a positive caster.
Bringing this to the top to add specs.
My search for write up tips brought me here.
I bought the Chase system today and talked to Mike at Rockstar Trux about the same question.
Though KORE builds them for stock specs, the static caster will change when lifted, due to the link configuration.
Mike's reccomendation, which is second hand from either a dealer tech or a KORE tech, is 2. 5 to 3. 5 degrees, possitive.
Eccentric bushings are on the axle side lower links for adjustment.
i am kinda in the same boat. i just finished a LORENZ system with his new IR coils and will wait a little before an alignment, to let everything settle and 500 miles to retorque everything. i have also heard about the caster issue. someone should have some experience in this issue. thanks and happy trails.
