I don't understand your question about the lower ball joints??
At some point Dodge changed the design of the ball joints, maybe 2000 models and newer, camber adjustment may be different on those trucks??
I posted this in another thread about camber adjusters:
The Dana 44 in the 1500 and light duty 2500 is non adjustable, the Dana 60 in the 2500 HD and 3500 has the bushings. You don't adjust the ball joint you install a different bushing. Look under the nut for the upper ball joint, the round thing with a split on one side is the bushing. I found these on the Federal Mogul site. Federal Mogul
View: Federal Mogul Full
Vehicle: 1995 DODGE TRUCK RAM 2500 PICKUP 6-360 5. 9L Dsl
Lookup Type: Group - Suspension Parts
Camber/Caster Bushing
NEW DESIGN
0 DEGREE PLUS OR MINUS K8958 94-99 1
NEW DESIGN
1/4 DEGREE PLUS OR MINUS K8959 94-99 1
NEW DESIGN
1/2 DEGREE PLUS OR MINUS K8960 94-99 1
NEW DESIGN
3/4 DEGREE PLUS OR MINUS K8961 94-99 1
NEW DESIGN
1 DEGREE PLUS OR MINUS K8962 94-99 1
NEW DESIGN
1 1/4 DEGREES PLUS OR MINUS K8963 94-99 1
NEW DESIGN
1 1/2 DEGREES PLUS OR MINUS K8964 94-99 1
NEW DESIGN
1 3/4 DEGREES PLUS OR MINUS K8965 94-99 1
NEW DESIGN
2 DEGREES PLUS OR MINUS K8966 94-99 1
NEW DESIGN
2 1/4 DEGREES PLUS OR MINUS K8967 94-99 1
NEW DESIGN
2 1/2 DEGREES PLUS OR MINUS K8968 94-99 1
NEW DESIGN
2 3/4 DEGREES PLUS OR MINUS K8969 94-99 1
Here's the Ingalls link
Ingalls engineering
There are also adjustable ball joints available from Ingalls engineering and possibly others.
Jared
