2nd Gen Non-Engine/Transmission alignment
2nd Gen Non-Engine/Transmission no 4-wheel drive
2nd Gen Non-Engine/Transmission 2nd gen frame stretch
is there any better wheel alignment for 2002 2500 iv have tried Caster 3. 2 3. 5
Cross Caster -. 3
Camber -. 10 -. 10
Cross Camber 0. 0 and i have tried stock setting the 3. 2 setting tore out my ball joints and the stock setting wore tires out so whats the best setting for my dodge thanks
You might try a search in Andy Redmond's posts to find one titled "01 camber adjustment".
His recommendation is for 3. 2L and 3. 5R for caster, -. 10 for camber both wheels and standard toe specs and suggests a slight toe out if you tow alot.
Since my truck has no camber ajustment I put all of the + caster I can get and set the toe to O and it steers as well as a Ram can. I just got the 16. 5 Warn and the Road Armor (don't even ask me about them) bumper on and reset things in my garage. I am going to take it to an Alignment shop and have it checked though. Like I said, it steers well, I just don't think that I can be as accurate with my string and tape measure as a Hunter machine can be.
