OK, I will start at the top. Yesterday while looking under the hood preparing for pyro/boost gauge install a big thunderstorm moved in while I had the hood up on my truck letting it cool down. I didn't think too much about it since I have washed the enigine off numerous times.
Well, I got up and hit the interstate this morning only to be greeted with problems. While climbing the mountain the truck lost power and oil pressure dropped shortly afterward. I didn't worry too much about the gauge since I know the sending units are prone to failure. I proceded to limp it up to the rest stop and shut it down. The pedal to the floor would only get me 50 mph. Upon shutting it down I checked everything over and called my sister for a ride. While waiting for them to pick me up I disconnected my EZ to try to trouble shoot the problems. The truck fired up and ran great, but the oil pressure was intermitent. Well I decided to drive it home once the oil pressure started to register again. Now I have the following codes.
237- map sensor low voltage
522 -oil pressure sensor low
1488- aux 5 volt supply output too low
5 volt supply voltage low
and the usual 1693
My question is do you think that moisture is causing all the problems? I have since reinstalled the EZ and it ran fine for a trip around the block, but then acted up again when I left the house a second time.
and the usual 1693
