I have Bill K's picture also, and the problem is, It's upside down. The screws are on the driver's side of the truck, one is above the edge of the transmission pan. The other is about even with it. The lowest one is on the right, against a flat metal plate and you need to turn it COUNTER CLOCKWISE to increase line pressure. One turn = 3 psi. The other screw is a couple of inches to the left, and an inch or so higher. It requires the short end of the allen screw be cut or ground down to about 1/4" in length so you can use it above the bottom lip of the trans casting. Turn this screw CLOCKWISE for later shifts at light throttle, one turn = 75 RPM.
