Yeah I've got the pinouts. .
Hey CJohnson... You read my post on POR?
Little known fact here:
Allison TCM's are available to the public. Allison calibrations could be bought at any distributor. You can buy the TCM through the distributor. Get ready to spend a grand. . plus 350-500 per calibration.
I know that the chick on POR is a tech for S&S, and you can use her for info. . Not knocking her, but I worked @ Allison's World Headquarters in Indianapolis.
I Know for a fact. You DON'T need a test stand calibration. There are calibrations out there for cummins motors. When I worked in the service dept, I could take any software level, any calibration, and put it on the eddy current dyno, and test it. The only inputs the TCM saw, were throttle position and range selection from the NSBU switch. You don't have to have a connection to the 1939 backbone for the trans to operate.
The main reason that allison's uses the serial communication between engine & trans, is for torque management purposes.
The engine actually reduces power between shifts, to save the transmission. This is not the only reason. . Since the new engines are fly by wire, it's much easier to use a digital TPS signal over the 1939/1850 backbone vs an analog signal from a TPS sensor.
Our test stand in the dyno room had a TPS attached to the dyno's throttle lever. . No standalone computers. . No magic boxes. . no voodoo magic. It's simple electronics. The Allison TCM doesn't care where the signal comes from, as long as it knows TPS & range selection.
I'm working on a swap right now. . I'll take pics & document it all. . including software levels, calibration & everything. . guess somebody's got to prove it for people to listen.
I'll keep y'all posted.
