I've noticed that many of the posts have come from people in cooler climates. I have found that cooling anything above 100 degrees tends to get exponentially more difficult. I have an electronic thermostat in my house here in Phoenix an I can monitor how long the A/C runs. It will run from about 30 minutes to 3 hours per day when it's between 80 and 95 degrees outside (approximate of course). When it gets to 110-112 degrees here, my inside A/C unit (in my house) will run for 15-16 hours. This shows you how much of a losing battle the A/C has to deal with in higher temps. In addition to heating the interior space, the A/C unit has to deal with the radiating heat off the walls. The heat just gets the better of the insulation... once the interior walls start to get warm it's all over. Just think of the walls as a radiant heater that puts out BTUs. One somewhat off the subject example is I'm currently at work working in one of our computer networking closets. It's 4ft wide and 11 feet long. I have a portable A/C unit in this closet to keep things cool (I just installed it Monday). I'm currently staring at the box and it says that it's rated for 8500BTU. According to the instruction manual, it can cool a 250 sq/ft room... my room is 44 sq/ft. I can barely keep it to a tolerable level in there w/out the main A/C on also... and this is in a 44sq/ft room! The air blowing out of it is cold as heck, but still not enough to fight the battle of dealing with the networking equipment's heat. In the main computer room, I have no problem keeping the room at 68 degrees during the fall/winter/spring months but in the summer time with the roof/walls baking I can't keep it below 80 degrees... big difference several degrees outside makes. Now try to relate this to RVs... An RV has far inferior insulation value compared to a home or office. Just imagine the losing battle it has to deal with.
In conclusion, I just wanted to point out the difference a few degrees can make when you're wondering why your A/C unit that your using in Imperial, CA isn't able to perform quite as well as someone who lives in Washington or even someone that visited Arizona in the spring time. I personally deal with it because the climate I live is similar to yours. I can run my 1 13,500 BTU A/C unit in my 26ft rig and keep it comfortable up until around 98-100 degrees, after that it seems like the interior temperature increments 1 degree for every 1 degree the outside temperature increases after 100 or so degrees. This is why I installed a second A/C unit. Your A/C unit is rated at a much higher BTU but it's a basement model. In my opinion, it takes a basement model more BTUs to cool a similar space. I don't know if it's because it has more complex air ducts, or because it may be hotter where it's stored, or because it doesn't have the air flow that a roof model has but I would say your larger basement model is probably equivelant to a 15k BTU roof mounted A/C unit. Don't get me wrong, I wish I had a basement unit. I just think that although you have a high BTU rated A/C unit, it probably performs similar to how mine does in the extreme heat with regards to the temperature it can maintain.
Oh, one more thing... Back to my interior walls generating BTUs theory... I have a generator in my rig. If I'm going on a trip in the summertime here in Phoenix I start my generator and get the A/C unit going before I start my trip so it has a chance to get a head start. Since I leave in the morning, the whole rig hasn't had a chance to get crazy hot yet (I just made up a new term). Also, if I think I'm going to camp by the lake in the summertime, I bring my rig to the house, plug in, and get the A/C going the evening before... then I start up my generator, turn back on the A/C and head down to the lake. You don't want to start off a trip in 100 degree plus weather without first getting the core temp of your rig down well before you start to camp or else your rig will be hot as heck for several hours.
All this of course is IMHO.
