Alt wiring
Chev/6BT for sale in NM...
03 Chevy conversion
Can anyone show me a wire diagram how to wire a 94 12v alt with out using the computer ?It's going in a 86 chevy,its all weaned from the computer except for the charging.
Thanks Brian
I used a 2 terminal heavy duty electronic regulator for a mid 80s Dodge.
The mid terminal on the reg. is the "I" terminal. Run a wire from it to one of the small terminals on the back of the alternator and splice to it a 12 volt signal wire from the fuse box or ignition switch, {12v power with key on run only}.
The other terminal on the reg. is the "F" terminal. Run a wire from it to the other small terminal on the alternator.
we relocate the (stock in your case chev) alternator with a bracket, double pulleys, new belts, usually relocating the ac at the same time.
dawna
