I installed the schraeder valve hose from Geno's and it worked fine for a while but started having the same problem - erratic pressures on my SPA gauge. With the digital readout and much finer measure increment - 0. 1 psi - it was really noticeable. It would fluctuate all over the place, from very high to very low.
Long story short, ended up replacing the sender, which worked for a while, then it happened again. Ran a test with a Fluke meter installed in the plumbing to verify the pressure. The pressure sender "started" working again - came to the conslusion that air was building up slowly in the line and causing erratic pressures. Installed a 3-way and needle valve so I can bleed the line and pressure sender. Seems to work fine. Whenever it starts reading erratically, I open the needle valve with the truck shut off, close the valve, start it up, and the erratic pressure readings go away - until the next time.
IMHO, this is a PITA. A friend has the exact same setup except the pressure line is off of a tapped banjo. He hasn't had a problem. Must be that the schraeder valve connection point off of the VP44 must allow air bubbles to slowly accumulate - argues for the FASS, eh?
