Guys,
Any of you ever set down next to a glowing fire and curl up with your 5. 9 Service and Repair Manual? (Cummins # 3666087-01) It's a real good way to get to know your engine. It will give you insite to other aplications as well as HP ratings/rated load speeds etc. etc.
Listing of two types of fuel lift pumps found;
Diaphragm and Piston
Of particular interest is the piston pump used on B series engines equipped with the distributor injection pump.
Part no. 3918076 and part no. 3918000 piston pumps.
Will these work on our engines? (to supply increased flow to a high performance VE) I'm thinking the cam may be different as they are used on much higher HP engines.
The engines using the P7100 injection pump have a different part no. listed. In fact the book gives a listing of about 12 different lift pumps and corresponding flow volume.
BTW anyone ever wonder what the little shield is at the rear left corner of our cylinder head is for?? KSB 3-ohm resistor
-S
-S
