BDaugherty
So I got a call from a guy stuck a couple hours south of me. He has a '99 2wd dually stock other than the low pressure fuel system and the old school hotter ECM that you used to buy back in the early days of the 24V. He said his volt meter is pegging high around 18 volts. He swapped in a parts store alternator with no change.
Voltage regulator is in the PCM on these trucks, right? After cleaning grounds, what's the next step? Verify wiring at the alternator plug and make sure it has continuity back to the PCM? If the problem is internal to the PCM, can it be sent off from repair or is it easier to just swap in an external voltage regulator? Advice or links to a write-up would be greatly appreciated.
