Rebel. good question! I looked in my '93 FSM, and it's clear as mud!
After pawing thru the electrical section, I found where it shows both small terminals as fields. So both of those are fields. Both are switched power, 1 by the ASD relay, and the other by the PCM. It shouldn't matter which one goes where, but if you wanna be fussy, the upper small terminal should be dark blue, and the lower is dark green.
