This is sort of a general automotive question, but it should be of interest to anyone who runs a heavy slide-in campers at different altitudes. When I pump up my tires at home (5400 ft) to 65 psi front and 80 psi rear and check the pressures at sea level, the front pressure is just under 60 psi and the rear is about 73. If I adjust the pressure at sea level to 65 and 80, the tires read 70 and 88 at home. So the rear pressure at high altitude is now 10% over the max recommended operating pressure of 80 psi. I routinely drive as high as 10,000 ft and am over the max GVWR, so I’m worried about damaging the rear tires. So my question is: Since a tire gauge measures the difference between atmospheric pressure (lower at high altitude) and the pressure inside the tire, should I adjust the tire pressures for sea level (overinflate about 10% at 5400 ft)? Or, would it be better to adjust the rear tires to a measured 80 psi at 5400 ft?
1999 Quad cab 2500, SB, SLT, 4X4, 5-speed, 3. 54, tow and camper package, Lance 820 camper, Lance cabover stabilizers, Rancho 9000s, Airlift airbags
