Alum rims on 93 dually HELP NEEDED
Access Plug
Odor from the Canister for Crankcase Breather Valve(CBV)
tried ultra rims on 93 dually
fronts will fit w/ some grinding on calaper
rear need flat mount rims for inners
stock rim has lug hole ridge around it
dealer said due to flat sides on alum rims
they need a flat surface rim to go against
the inner rim.
WHO has info on flat lug hole rims
with hole for 5/8 '' lug???????????
i was very upset
i dont want to buy 6 alum rims
bill
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
I'm running all 6 aluminums on my 96.
There are a few advantages to this:
1- lets you rotate the inside-rears with the fronts, and you can swap the outside rears side to side
2- your truck will feel much "lighter on its feet" when all the steel rims are gone - they weigh a ton in comparison
3- steel and aluminum wheels will suffer chemical reactions if too much grime builds up in between them - the metals corrode very differently
I have the Mopar aluminum wheels that resemble the Alcoa LTS rims. They use the factory lugs, but I sprung for the McGards
I have not regretted the decision to go all-aluminum.
1996 3500 Club 4x4 Laramie SLT, unmodified 180/420 12-valve, 47RE automatic, 3. 54 limited slip
[This message has been edited by KCJackson (edited 05-07-2001). ]
