Material Samples: Small sizes of the following alloys: 2017, 3003, 4032, 6020, 6061, 6262, 7068, 7075, and Microporous Aluminum.
Alloy 1100 Aluminum: Commercially pure, this alloy has more thermal and electrical conductivity than other aluminum alloys. It is not heat-treatable, it offers excellent corrosion resistance and workability, and it's easy to weld and braze. It's ideal for chemical equipment, heat exchanger fins, and sheet metal work. Yield strength is 17 ksi. Hardness is 32 Brinell. Melting range is 1190° to 1215° F.
Alloy 2007 Aluminum: This alloy's excellent machinability makes it an ideal choice for screw machine parts, tube fittings, hose parts, and any component that requires extensive machining.
Alloy 2011 Aluminum: Heat-treatable alloy has great machinability and fair corrosion resistance. Superior free-cutting properties make it a prime choice for screw-machine products, tube fittings, hose parts, and many other machined components. Yield strength is 43 ksi. Hardness is 95 Brinell. Melting range is 1005° to 1190° F.
Alloy 2017 Aluminum: Stronger and easier to weld than Alloy 2011, this heat-treatable alloy also offers good machinability (although it is not as easy to machine as Alloy 2011). Workability and corrosion resistance are fair. Use for screw-machine products, tube fittings, fasteners, and needles. Yield strength is 40 ksi. Hardness is 105 Brinell. Melting range is 955° to 1185° F.
Alloy 2024 Aluminum: One of the “aircraft alloys,” this heat-treatable alloy has high strength with fair formability and workability, so it works well for spot welding. Use for aircraft parts, fasteners and fittings, wheels, and scientific instruments. Yield strength is 47 ksi. Hardness is 120 Brinell. Melting range is 935° to 1180° F.
Alloy 3003 Aluminum: This alloy may be strengthened only by cold working. It is not heat treatable. Similar to Alloy 1100, but with slightly higher strength, this alloy has good weldability and workability and offers excellent corrosion resistance. Use in chemical and food-processing equipment, tanks, heat exchangers, and sheet metal work. Yield strength is 21 ksi. Hardness is 40 Brinell. Melting range is 1190° to 1210° F.
Alloy 4032 Aluminum: Featuring high silicon and nickel content, this heat-treatable alloy provides superior wear and abrasion resistance as well as good machinability. There is no need for hard-coat anodizing often required in applications using Alloy 6061. Ideal for automotive, aerospace, electronics, appliances, and hydraulic/fluid power applications. Yield strength is 46 ksi. Hardness is 120 Brinell. Melting range is 990° to 1060° F.
Alloy 5005 Aluminum: This aluminum alloy has mechanical properties similar to 3003, but is stronger. Brighter finish than alloy 5052. Readily welded and has good corrosion resistence.
Alloy 5052 Aluminum: Stronger than Alloy 3003, this alloy offers excellent corrosion resistance (especially in marine environments) as well as good weldability and workability. It is not heat treatable. Ideal for tanks and drums, marine and vehicle bodies, and fan blades. Yield strength is 28 ksi. Hardness is 60 Brinell. Melting range is 1125° to 1200° F.
Alloy 6013 Aluminum: This heat-treatable alloy offers the corrosion resistance, weldability, and thermal conductivity of Alloy 6061 with improved machinability and greater hardness. It also has the strength of Alloy 2024. When machining, this alloy breaks into small chips, reducing downtime caused by metal buildup on cutting tools. Yield strength is 62 ksi. Hardness is 130 Brinell. Melting range is 1052° to 1195° F.
Alloy 6020 Aluminum: This is a lead-free alternative to Alloy 6262 with excellent machinability. Heat treatable, this free-machining alloy produces very small, broken chips, enabling higher productivity by allowing faster machining speeds and shorter cycle times. It offers an excellent surface finish as well as superior corrosion resistance and improved anodizing response compared to the highly machinable Alloy 2011. Applications include master cylinder pistons; valves; and hydraulic parts used in automotive, fluid power, and electronics industries. Yield strength is 42 ksi. Hardness is 100 Brinell. Melting range is not available.
Alloy 6061 Aluminum: Extremely versatile, this heat-treatable alloy combines good weldability and formability, high corrosion resistance, and medium strength. Use it for chemical equipment, vehicle parts, scaffolding, and pipe fittings. Yield strength is 37-40 ksi. Hardness is 80-105 Brinell. Melting range is 1080° to 1205° F.
Alloy 6063 Aluminum: Superb corrosion resistance and ready weldability make this heat-treatable alloy great for outdoor applications such as architectural trim, railing, and piping. Yield strength is 21 ksi. Hardness is 60 Brinell. Melting range is 1140° to 1210° F.
Alloy 6262 Aluminum: This heat-treatable alloy boasts excellent machinability and good corrosion resistance. It can be readily welded and accepts coatings well. It has good finishing characteristics (a bright, smooth finish is easy to obtain). Use it for valves, piston, hinges, and fittings. Yield strength is 55 ksi. Hardness is 120 Brinell. Melting range is 1080° to 1205° F.
Alloy 7068 Aluminum: Offering extreme high strength, this heat-treatable alloy is significantly stronger than Alloy 7075 with comparable corrosion resistance. Originally developed for ordnance applications, it is now being used for aircraft and vehicle parts as well as other applications requiring extreme high strength. Yield strength is 99 ksi. Hardness is 190 Brinell. Melting range is 890° to 1175° F.
Alloy 7075 Aluminum: One of the hardest aluminum alloys, this exceptionally strong, heat-treatable alloy has good machinability and fair corrosion resistance. An “aircraft alloy,” it is ideal for aviation parts, keys, gears, and other high-stress parts. Yield strength is 73 ksi. Hardness is 150 Brinell. Melting range is 890° to 1175° F.
Alloy MIC-6 Cast Aluminum: This alloy features outstanding machinability and stability. Formed into cast plates, stress relieved, and precision-ground on both sides.
Alloy 630 Aluminum Bronze: This aluminum bronze offers excellent resistance to corrosion and high tensile strength. It has a hardness of Rockwell 96B and a yield strength of 65,000 psi.
Alloy 642 Nonmagnetic Aluminum Bronze: The high aluminum content of this bronze make it nonmagnetic. It has excellent toughness and resistance to corrosion and can be heat treated for greater tensile strength. This metal's hardness is Rockwell 90B and its yield strength 60,000 psi.
Alloy 852. 0 Aluminum: The most widely use aluminum-tin alloy, often used as an alternative to bearing bronzes. Its low weight, excellent corrosion and wear resistance, formability, and high thermal conductivity make it ideal for bearing applications.
Alloy 954 Aluminum Bronze: The most common aluminum bronze. For pressure-bearing surfaces where strength and hardness are a must. Also for use in high temperatures and for heavy duty road and earth-moving equipment. All forms but ingots meet ASTM B505. Ingot composition is 83 copper, 10 to 11. 5 aluminum, 3 to 5 iron, 1. 5 nickel (including cobalt), and 0. 5 manganese.
Alloy 959 Aluminum Bronze: This alloy is characterized by high strength and excellent corrosion resistance. It can also be heat treated. Uses include a variety of heavy duty mechanical and structural products including gears, worm drives, valve guides and seats.
Microporous Aluminum: Porous aluminum can be used to filter air, gases and low viscosity liquids. Sheets are made from pure aluminum powder and an epoxy resin. Material can be used to create blemish-free molds for vacuum forming and thermoforming. Temperature range: -20° F to 900° F. Hardness is 32 Brinell.
Aluminum Honeycomb: Use these commercial-grade core aluminum sheets to make your own composite panel combinations. Honeycomb core sheets are strong and lightweight. Fire and water resistant.
Aluminum/Thermoplastic Composite: This composite has an LDPE core with painted finish to provide the rigidity of sheet metal with the lightness of aluminum.
