Aluminum Trailer Low Profile
big 38~40" street tires??
Optima Batteries
6'x6" wide, 20' long bed. Overall length from the hitch to the back is 25 feet. Two 12" wide x 6' long aluminum hide away ramps. The deck is 1/8" aluminum diamond plate. Cross stringers are 16" on center. Two 3,500 lbs. capacity torflex axles, both with electric brakes. All bolts used on this trailer are stainless steel. 2 5/16" A-frame 10,000 lbs. capacity coupler ball hitch. Top wind A-frame jack, 14" lift, 5,000 lbs. capacity. Has a 2"x 6" caster wheel for easy moving when unhooked from vehicle. Heavy duty safety chains. Aluminum diamond plated A-frame tool box. Size 40" wide in the back, 22" wide in the front, 22" long, 19" deep with lock. Contains a large 12 volt battery which runs the emergency brakeaway brake system. It also, runs an 8,000 lbs. capacity ramsey electric winch. Battery is being charged at all times when hooked to vehicle. This is called a trickle charge. Two 1 1/2" x 15' long 5,000 lbs. capacity ratchet straps. Tires and wheels. Wheels are steel modular trailer wheels, 15" x 6 hole bolt pattern. Tires are heavy duty rated. Removable fender. Six tie down pockets welded on each side. Back of trailer has a load stabilizer for each side, to be used when loading a vehicle. Total weight of trailer is 1,380lbs. Title classification is 10,000 lbs. gross.
Asking price $10,500. 00 dollars, or make offer.
Visit our website for more detail
dnfmcc22@aol.com
You should try to put this in the classifieds, there is no selling in the forums and a moderator will probably remove it when they see it.
