I got to thinking about the intake air temps recently and I recall in another thread that the turbo heats to some 200+ degrees, and the charge-air-cooler reduces it to about 20 degrees above outside temps. This seems to make sense, but I'm trying to figure out what happens when the entire CAC is blocked off. When it's -20F, I block the entire grill with a sheet of canvas behind the grill right in front of the radiator. This makes the truck run at almost normal temps, but what affect is it having on engine performance? Should I open it up a bit and deal with the decreased engine temps, am I doing the best I can, or am I just stuck in that never-never land of turbo pro's and con's?
Thanks,
-Adam
Thanks,
-Adam
