Ok so my dads 06 is having problems with the trailer wiring. I knew exactly what was wrong since I worked at the dealership and see so many trucks with the same problem. We are gonna re-wire the whole boat trailer just to make sure we weren't the ones that caused the problems in the first place. What I have found on the trailer is that between the tail lights and turn signal wires they have continuity. Is this suppose to happen? I would think that the turn signals and the tail lamps would be on two different circuits. But now that I think of it, would it have continuity since they share the same ground (through the trailer).
What it comes down to, on the 06's and newer the computer is looking for either a ground or it even looks for a short to power so if there is power going down a wire that it shouldn't, it will shut the power off to the trailer.
If somebody could please check to see if their trailer has continuity between the turn signal and tail lamp wires.
Thanks
Thanks
