We all agree that the stock auto is less than marginal at best. If you tow in od then you will have transmission failures. Not enough precise info available.
The 99 2500 4x4 auto is rated at gvwr 8,800#
354 max trl wt 9,800# cgvwr 16,000#
410 max trl wt 11,800# cgvwr 18,000#
99 2500 2x4 auto is rated at gvwr 8,800#
354 max trl wt 10,200# cgvwr 16,000#
410 max trl wt 12,200# cgvwr 18,000#
You did not say wether you had a 4x4 or 2x4 or which axle ratio
precise Information is imperitive for informed or correct responses !!!!!!!
The diff in ratings is based on the added stress on the transmission with the 354 gear.
