OK, I did a search using "limited Slip" and went back to 2004. I didn't see any posts with a good explanation of how the TracLock differential works. Many bad mouth it, but once you see and understand how it works, you will see that the torque handling is probably superior to a clutch design. Also once you see how it works, you will understand why it requires special fluid WITHOUT friction modifier, PN 05102232AA.
I couldn't get my markup program to work, so I'll just have to explain it best I can. Sorry for the fuzzy photos, didn't have my camera with me at school so had to use my phone.
The first photo shows the two helical gears, the two "brakes" that are the silver piece at the end of each gear, and one side gear that the axle goes through. There is a second side gear that the other axle splines to. The helical gears (6), and the brakes (6) reside inside the carrier. If there is no difference in wheel speed, all the pieces rotate together with the differential housing.
The next photo shows the parts in the differential. Note that the side gear meshes with only one of the helical gears (there are three such sets), and the brake has a clearance cut out so the side gear misses it. At the top of the photo is where the opposite side gear would be, and it meshes with the other helical gear and misses the brake.
The third photo shows just the brake installed in the differential. Note the relief notch cut into the brake. It is in the hole to the left, and the notch is in the 2 o'clock position. That allows the oil film to get out from between the helical gear and the brake so the helical gear will stop trying to rotate. This is where the proper fluid comes in. In order to work, the gear has to "punch through" the fluid film on the brake and stop the spinning. Friction modifier is slippery and it keeps the brake from working properly.
Now this is how it works. Picture one wheel (side gear) spinning on a loose surface. The helical gears are spinning opposite directions, and they want to push each other apart (each one toward their respective brake). If there is some resistance to rotation (the other wheel has some traction, vehicle brake applied slightly) they want to push apart really hard. That stops the rotation of the helical gears (because they are pushing hard on the differential brake) and essentially "locks" them together. Since they are locked together, and the side gears are in mesh with the helical gears, both side gears and the axles have to spin at the same speed. And the more resistance applied to both wheels makes the helical gears push that much harder against the brake, allowing lots of torque to be passed through to the axles.
I hope this was a clear enough explanation, if not ask away.
