American Axle makes the axles, who makes the Limited Slip?
Does new 3500's come with 17' wheels
Radiator Capacity
OK, DC dropped Dana so AA (American Axle) is the supplier for
the new G3 axles. AA also makes the axles for the GM 2500HD
and 3500HD. The GM trucks have a limited slip made by Eaton.
>Click here for info on the Eaton locker<
I have owned a couple of GM vehicles with this diff (Eaton
Positive Locking differential). It is RPO G80 on a GM.
Basically I am trying to find out if Dodge is using the same
differential in the new trucks or just a plain old clutch type
limited slip.
The neat thing about the Eaton? It is a true locking diff.
You can have one rear tire completely off the ground and
still get 100% of the power to the tire that is on the ground.
The limited slip DC offers in the Dana axles is a clutch type
and will only hold a certain amount of torque before slipping
and therefore you can get stuck, spinning one wheel even
though it is a posi/limited slip.
Anybody know what is in the new G3 rear alxe?
*EDIT added*
I just found the AAM website and they show some different differential
units. I'm hoping the new Ram's have the TrakRite LK diff.
-Chris
I read somewhere that the DC axles made by AA don't have clutches and don't need a limited slip additive. It uses a "helical gear design", whatever that means according to the press release.
Casey
According to a email from AA Dodge is using the TracRite GT. Couldnt tell me the tourque bias but they run from 1. 5 to 2. 5 if my memory serves me right
