I decided to run the traps on some info I came across in a post recently re: the proper weight rear gear lube for the AAM axle. I called American's 800 number 800 299 AXLE (2953) and spoke to Bob Dunn. He verified that we should be using 75/90 weight and it should be full synthetic with NO additive. DCX puts 75/140, I understand, in these rear ends. He said they've been trying to get that corrected for 2 years,... go figure. I for one was interested since I put a Mag Hytec cover on and filled it with the wrong stuff and also put in the additive. Thought someone else could benefit from this info. The proper DCX part number for the right fluid is 5102232AA.
