This info is straight from DC Technical Training Group.
The following is the fluid level as shipped from the assembly plant. It is most likely different from the information in the owner’s manual. However, it is the opinion of DC that filling the axle to a level higher (say to the level in owners manual or bottom of the fill plug at worst case) will not have a detrimental effect on the axle (leaks). So it won't hurt anything but your wallet for the extra synthetic lube.
2003 DR light duty (Ram 1500) and Heavy Duty (2500-3500) rear axle fluid level may appear low. Be sure that you are checking the correct level requirement for the axle application.
2003 Light duty 9. 25 Corporate rear axle fluid safe level should be 5/8" below the fill hole. All 2003 light duty DR receive and should be serviced with SAE 75W-140 GL-5 synthetic fluid PN 04874469. Note: if 9. 25 axle has limited slip differential, additive must be added.
2003 Heavy duty (2500-3500) 10. 5 American Axle rear axle fluid safe level should be 3/4" +or- 1/4" below the fill hole. All American Axle's receive and should be serviced with SAE 75W-90 GL-5 synthetic fluid PN 05102232AA. Additive not required if Trac-Rite differential equipped. 2003 Heavy duty 11. 5 American Axle rear axle fluid safe level should be 1" +or- 1/4" below the fill hole. All American Axle's receive and should be serviced with SAE 75W-90 GL-5 synthetic fluid PN 05102232AA. Additive not required if Trac-Rite differential equipped.
