I'm looking for advice from anyone with the TrueTrac carrier in their rear diff. Does your diff feel like it is grabing while you turn with a load on or behind you? I'm about 10,000k or so into the truetrac carrier and just in the past few weeks while on holidays it seems to "chatter" or cause a jerky tug while turning. It is only noticable with a load in tow. I go lightly on the throtle while turning, but obviously have to push a little to go. The diff just went through another good cleaning with the axles out and cover off to make sure it is clean and little was found. The only change is that instead of Amsoil, it has Lukes lube in it now. I wouldn't think that would make any difference would you?
It seems to keep on producing metal pieces that look like the old carrier gears!!!. been cleaned 6 times in 10,000k and seems to keep coming up with debree.
I just want to see if what I'm feeling is the normal operation of this carrier. I have heard it refered to as a "harsh" carrier.
