Amount of Gear Lube in Mag-Hytec
How much gear with Mag-Hytec diff. cover?
  • Factory level - 4 quarts
    Votes: 0 0.0%
  • 4-5 quarts
    Votes: 0 0.0%
  • 5-6 quarts
    Votes: 10 34.5%
  • 6-7 quarts
    Votes: 7 24.1%
  • Filled up to the top line - 8 quarts
    Votes: 12 41.4%
  • Total voters
    29
  • Poll closed .
Cant Decide Which Rocker Panel?
Most Controversial
I'm trying to find out how much gear lube CTD owners with Mag-Hytec differential covers are running in their differentials. Please post if you have ever had any leaking seal problems, i. e. pinion seal, wheel bearings, etc. TIA
John
I filled mine with Royal Purple Synthetic 75-140. I have not added any frction modifier and have no chatter. Cant wait till they make one for the front :) .
I emailed Mag-Hytec concerning the front cover. We have all been waiting patiently for this to come out. Roy @ Mag-Hytec via Email stated that we should see this in late fall. :D I know we have heard this before but I think if we wait patiently, It will come ( thank god ;) )
I have just ordered the rear cover myself and I'm planning on using Amsoil 75w-90.
John, your running the 3500 as I am so we both have Dana 80's.
when I had mine serviced and the Mag-Hytech cover put on we put 7 1/2 quarts in which put it in the middle of the fill zone. I think there is some difference as to how we all look at the dip stick but if you get 7 or a little more in there you will be on time..... Pete
My Dana 70 took 5 1/2. The install took a while as I had to fill factory stampings ( on the diff housing ) as per the instructions that came with the cover. 3000 mi, no leaks. :)
Fireman
My cover didn't mate to the new housing and is leaking at the bottom. I ordered some Amsoil synthetic and as soon as I get it I will be taking the cover off and checking for stamps. I may need a new O-ring, but I seriously doubt it. I loosened the cover up last night and re-tightened it, still leaking, but I think it slowed down some. If push comes to shove I'll use the orange RTV. At least I can fix this problem. When it comes to warranty work, they never come out of the repair exactly like they went in. :(
Nope, fill!
Originally posted by klenger
Could you mean the you had to "file factory stampings ... " I was a little confused at first.
Some of the stampings are so deep, the o-ring will leak. I bought mine used and the previous owner didn't include THAT SHEET in the instructions!:mad:
I called Roy (nice, helpful guy) and he told me about it. He said the techs at a garage will (after filing the burrs off) use silicone to fill them up but most DIY types use epoxy so it only has to be done once. That's what I did. I then made sure the whole surface was dead flat and smooth. No leaking!
Gents:
You may want to specify Dana 70s and Dana 80s. I think stock Dana 70s hold 7. 5 pints and Dana 80s hold about 10. 1 pints.
Filling my Dana 80 on level ground to the top of the dip stick took 14 pints.
Wiredawg
I put black silicone on my Maghytec as though it were a factory pan. The reason is that I dont want water to seep between the Maghytec cover and the iron Dana 80 and cause rust OUTSIDE the o-ring. I have seen this happen before on other o-ring equipped covers. The silicone will seal the joint against water intrusion. This was not necessary because the o-ring would allow oil to leak out but just to keep water out. BTW, I used 7 quarts of Mobil 1.
I dont want water to seep between the Maghytec cover and the iron Dana 80 and cause rust OUTSIDE the o-ring. [/B]
I coated both surface with anitsieze. I'll report on it's effictiveness when I install my LSD.
