Archived amp meter
Archived Check engine light
Archived white smoke
your alternator or ECM charging circuit is bad... take your truck to an alternator shop and have them check it out. . they`ll prolly find the problem. . If you're under warranty still, however. . dealer city. . heh. .
ohya. . get a voltmeter and check the voltage on your batteries while running and not running... if its less than 12v you're not charging, and you shouldnt run the truck long.
-j
