I just got my Amsoil Air Filter the other day in the mail. I unfortunately forget the number right now but will check when I get home tonight for you. You will need to modify the Amsoil filter because they do not make it for a 1992. What needs to be done is find or create the Metal round part that goes up against the inside wall. I figured that I would just see if I can take apart my original one and make that one fit. Basically all that comes from Amsoil is a hollow air filter and one end needs to be blocked. Maybe even a sheetmetal person would be able to create a simple one for little $$.
Scott
92 Ram, Bright White, Club Cab, LE package, 4x4, 130K, 3. 54 gears, Auto, Extra transmission Cooler, 285x75x16 Cooper Discovery A/T, 16X10 American Racing rims, RS9000, Tekonsha, Running boards, Lund Sunvisor & bug shield, Marker lights, Tonneau cover, Full cap, DynoMax, 5" Chrome tip, 16 cm Turbo, Isspro Boost, 23 lbs Boost empty, Oil Pressure Gauge, Pump Adj, Sprayed in Bed-liner, Rubber mat
'SHAKES, RATTLES & GOES'
