Amsoil announces NEW synthetic transmission fluid just for Dodge/Chrysler vehicles!!
grill inserts
Mopar Side Rails
As most of you know, Chrysler vehicle automatics transmissions require fluids with different friction charastics than Ford and General Motors vehicles. Amsoil Synthetic Automatic Tansmission Fluid, Chrysler ATF+(ATE) is formulated specifically to meet Chrysler specs for 100,000+ miles service!
Chrysler vehicles also require automatic transmission fluids with outstanding high and low temperature performance and oxidation stability--even better than those required by Ford and General Motors vehicles. Amsoil ATE outperforms conventional fluids in both. Synthetic fluids work better over a wider temperature range than conventional fluids do, and part of their superior temperature-handling ability comes from their ability to withstand oxidation in high temperature operations.
This new formulation is not to be used in Ford type F and Dextron applications.
Maybe we can now have a fluid that will help the one major weak spot in our Rams... the transmission. #ad
Any forum user that wants to get this product at wholesale just drop me an email.
D. O. C. I. Doctor of Compression Ignition
Get Amsoil at WHOLESALE (including the new synthetic transmission fluid made just for D.
C. automatics) BY PASS THE DEALER!!
-- email address removed --
[This message has been edited by VWTdi (edited 01-25-2000). ]
I put in this new transmission fluid, however I still had to use a friction modifier(lube guard)to eliminate shudder during lockup.
99' 2500 2wd SLT Auto LWB Quadcab "BANKS STINGER PLUS" (TURBO BACK 4"-STAINLESS EXHAUST, QUICK TURBO HOUSING, OTTOMIND COMPUTER,K&N FILTER, PYRO-BOOST & TRANS-TEMP GUAGES), 275hp RV INJECTORS,PROTORQUE CONVERTER, TRANSGO SHIFTKIT, AIRLIFT "SUPER DUTY", CENTURY "ELITE" CAP (LIMO BLACK ON WINDOWS),BEDRUG, SHELF-IT,PIONEER "PREMIER" CD W\CD CONTOLLER,YAMAHA PASSIVE EQ, ALPINE 200 WATT 4-CHANNEL AMP, POLK SPEAKERS, PUNCH 45 "STRAPPED MONO" (90WATTS) ON 12" BAZOOKA TUBE
VWTdi,
What Amsoil product is recommended for the tranfercase connected to a 5-spd?
Thanks,
Tim
94' & 96' 2500 4x4, 12v, 5spd.
Let me know what you are running in the transfer case now, which transfer case you have and what viscosity fluid. I will do a little research and let you know what is the best product to put in the T-case.
Former Cummins of Atlanta Technician
