Jetpilot, If I'm not mistaken, you are right in "MGM's" back yard. "MGM" is an Amsoil dealer (as are countless others on this BB... including myself) that would gladly get you squared away with what you want. Two, 2. 5 gal. containers of ATF constitutes a case so the price is a little better. BTW, I have been running the new Amsoil Universal ATF+4 in my DTT modified 47RE since mid January... in fact, I just changed the ATF again several weeks ago. Great stuff!
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & DD trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, "special" Brite-Box, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass w. trick billet block adapter and Aeroquip Teflon-s/s hoses, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP s/s fuel hoses, tricked out Cummins valve cover, tricked out Banks High-Ram and 14 cm2 (wastegated) turbine housing, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
COMING ATTRACTIONS: break out those sun glasses! Plus, BLACKOUT gets a "BIG GULP"
NRA Life (Patron) member
