the amsoil dual filter mount is the one that gave the problem. this was a very bad idea. stay with the lf16035 main filter and use a bypass filter of your choice. i run a fleet of dodges and have bypass filters on all of them. i have five different type mainly because i make them out of scrap parts or from a junk yard. the amsol single i think is a bmk21 and the filter is 110 i run two of them. i run more of the class 8 truck style filters because i have to stock them anyway, (they all come from the factory with them). the filters do not have a bypass built in them like the main filter has to have therefore you can run them until the clog up. this is the point that it filters its very best. at oil drain interval just feel of the filter and if it is still hot it is ok. the big truck filters hold between two and three quarts of oil and i do not like that much used oil left in. so i remove the filter, drain and replace. there is about 1,000,000 or more trucks out there running lf777 fleetguard filters and because of this the filters are very inexpensive. the wix # is 51749 the base is 89750 i think this is car quest # but will cross to others. the orifice is to large on the base for our trucks (the big trucks hold 44 quarts) and you have to make a smaller one. i make mine in the fitting that i screw into the top of the stock filter housing. i plug it up with a soldered in piece of shim stock and drill a 0. 032" hole in it. i return most back through the filler cap. some to the valve cover and a few to a second turbo drain. for you, you will need this port for the second turbo. use hydraulic hose and do not mount any filter on a bracket from the motor. there is a cross brace on the bed on the passenger side that i mount most of mine on. we test the oil on each series truck to set the oil change interval. the 04. 5 up trucks has the lowest mileage drain interval of any previous truck. on these it is a must to run a bypass filter. and for those i recommend a luber finer lfp9750 and a lmb451 base. the high price of the amsoil compared to the lf777 is the reason you will probably go with the lf777. on your truck i think you will find it only extends the drain interval by the % of extra oil the filter takes. i think it will be about 20,000 miles.
